Basic/Novice
Questions
What
do the driver T/S parameters mean and will they help me choose the best
driver.
Do
I need to apply any delay to drivers when using horns
Would I be better off using the PD
184 driver instead
of the PD 1850 driver in short folded horns
Which of these three RCF drivers will give me the
most SPL in a reflex box and why
Will the PD 186 or PD 184 driver give me the highest
output in a horn loaded cab
You
once said that bass drivers for horns should have an EBP of over 130, how
important is this
I
Have some question about the construction of the MT 102 mid top horn
Can
you tell me what’s the best type of top end to use with a 12” driver
I
need a system for doing small parties, should I use horn loaded or reflex
Which
specs should I look for in a driver for midrange horn use
How
do I calculate the extra space need that is taken up by a driver or port
in a box
Why
don't you like scoop bins
