Each of these
multiple horns should be designed as a single horn with a
single driver. Each single horn should have sufficient length
to support ¼ wl of the lowest frequency you wish to
reproduce.
You will also
need to calculate the required mouth area of the large horn to
reproduce the lowest frequency desired. Divide this mouth area
by the actual mouth area of one of your single horns. This will
yield the number of single box horns that would be required to
be combined together to obtain the mouth area needed for the
large horn.
As
mentioned elsewhere each single horns length could be
shortened anywhere between .6 and .8 corresponding to the
amount of single horns needed to create the large horn. Fewer
single horns would dictate less shortening, with larger
amounts of single horns needing to be shortened by a greater
existent for the same given fo.
Alternatively each single horns length could be left intact
and you would benefit from the new lower fo.
