Which loudspeaker software do you use/recommend |
Driver model with discrete elements System 'Dis '|Voice coil iimpedance 'I1' Node=1=2 Z={ Z=Ree + j*w*Le; } |Motor Gyrator 'G1' Node=2=0=3=4 Bl={Bl} |Mechanical part Impedance 'I2' Node=3=5 Z={ Z=Rms + j*(w*Mms - 1/(w*Cms)) } |Reverse diaphragm Coupler 'C1' Node=4=0=10 dD={dD| Front diaphragm Coupler 'C2' Node=5=0=300 dD={dD} |Radiation Radiator 'R1' Def='C2' Node=300 WEdge=20cm HEdge=50cm Def_Driver 'D1' Meas_DoNotModify dD=35cm tD1=-50mm |Concave dome fp=800Hz |Mass reduction frequency fs=60Hz Mms=58g Qms=3.41 Qes=0.32 Re=5.58ohm Le=85mH Inspect/Network Impedance |Impedance compensation Capacitor Node=1=0 C=20uF Rs=5ohm BassUnit 'B11' Def='D1' Node=1=0 x=0 y=-10cm z=0 HAngle=0 VAngle=0 WEdge=20cm HEdge=50cm Filter 'F1' fo=300Hz {b0=1; a2=1; a1=1.414214; a0=1; } |Diffraction of finite baffle System 'Bass' BassUnit 'B11' Def='D1' Node=1=0 x=0 y=-10cm z=0 HAngle=0 VAngle=0 WEdge=40cm HEdge=50cm Filter 'F1' fo=300Hz {b0=1; a2=1; a1=1.414214; a0=1; |
System 'S1' Horn driver Driver 'D11' Def='D1' Node=1=0=20=0 Duct 'Du1' |sound path around the voice coil Node=20=0 WD={pi*5e-2} |Perimeter of magnet cap (formula parser) HD=8mm |Width of magnet cap. Len=20cm |Depth of duct. |Begin of funnel with a duct. Duct 'Du2' Node=20=30 dD=10cm |duct diameter Len=10cm|duct len Vf=1.8cm3 |The mid section of horn is conical Waveguide 'W1' Node=30=40 Conical dTh=10cm |throat diameter WMo=50cm |mouth widthHMo=50cm |mouth height Len=20cm |funnel length Radiation part of horn exponential Horn 'H1' Node=40 T=1 |simple exponential flare WTh=20cm HTh=10cm |throat width/height WMo=50cm HMo=20cm |mouth width/height Len=50cm Rw=50cm Wc=20cm |radiation cone (horizontal) Rh=20cm Hc=10cm |" (vertical) x=0 y=0 z=0 |radiation position of horn HAngle=0 VAngle=0 Generate measured loudspeaker with menu point: | "Tools/Generate Def_MeasRadiator File" |from the files: | "\Import\Horn.spl" and| "\Import\Horn.imp" |Input voltage: Uin=2.83V peak |Distance: r=1.m |Cross section 10cm x 5cm |
I did said it wasn’t simple. You even have to manufacture your own horn from conical sections, ducts and funnels. So there’s no easy asking what happens if use a certain driver with a horn this long with a throat this big and a mouth this big. It is actually quite simple to use, its just that it take a life time to know what to enter. Akabak will also help you to design active or passive crossovers, many of the other programs listed here will do the same but Akabak allows you to insert any amount of filters anywhere into the chain and see what result it has on the plot. You can also design 4 or 5 way systems on Akabak, with each band having its own driver, cabinet and filter network. So that’s about it for speaker software. People often ask what program do I use. Well I use all of the ones listed above. You get to know how the results of all the different programs relate to how the product will sound when you build it. So for one project I might use all the programs to see what might happen. It kind of covers it from all angles then. If a friend of mine wants a simple sealed enclosure for the back of his car then I would use Bass Box Pro as there’s no point in looking into it any further. Bass Box Pro also has a nice feature that gives you the response for the back of a car, as it is very different form a cabinet in room response. If I’m asked to design a two way system with a 12” driver and a 1” horn in a trapezoidal box for a company then I would use Leap to derive the box volume and port sizes and then make the cabinet and continually make modifications and do listening tests until I was happy with the result. For horn cabs, be it bass or mid top designs I would use Akabak. I would also use David Mc Beans excellent Horn Response program. While it does not go into the depths that Akabak does it is really nice to use and you are able to see very quickly if a design is worth continuing with early on into the project. I like it for bass horns and it seems quite accurate at predicting what will happen when you finally listen and measure the design. Horn Response is a free program and I thank David very much for his input into making this planet a better place to be in with people such as himself giving so freely that which others would not. So as you can see there is no one program that does it all, I even have other programs (one by JBL) that fills the gaps that the other programs leave. I sometimes even resort to using a hand calculator and paper in making a design and then checking it in the software domain to see how accurate I was. I also use a 3D CAD modeling program to draw and plot the final plan of the design. All the plans on the speakerplans site were drawn by hand on a technical drawing board. One of my jobs in life is as a speaker and system designer, and so if I summit plans to a big company I always use the 3D computer CAD program as they are expecting it, I can also come up with a file that can be used by a CNC router for large scale manufacture. But for the simple plans on the speakerpalns site I like to resort to doing things by hand as I find it quite a relief from having to work with computers all day. So which program for who? If you’re a novice then don’t Leap into Leap or Akabak. They will do your head in and you will forget about speaker designing forever. Start off with Win ISD, it’s free and will teach you most of the basics quickly. You will need to know that if you make the rear chamber of a ported box bigger you can then reduce the length of the port, or that if you make the port diameter larger you will have to increase its length to achieve the same tuning frequency. Things like this can be learnt in all the programs, with the exception of Akabak, which assumes you know everything about speaker design. Akabak is a bit like a mirror in that it doesn’t tell you anything more than you know already, it just shows you what you do know and how to better to apply it. So the basics can be learnt form Win ISD, but when you grow out of that then Bass Box Pro should keep you happy for years. It will never really push you as a designer but will give you the opportunity to design some good sounding sealed, reflex, 4th and 6th order bandpass enclosures and even passive radiators. It takes enough detail into account to be able to construct a cabinet that will sound a lot like its plot suggests. If you get bored by this program and want to take it further into the scientific realm then get Leap. The ability to be able to make measurements is one of its strongest features, but the fact it takes a lot more parameters into account make it more suitable for the pro designer or very serious hobbyist. And finally if you are a nutter and your every waking and sleeping thought is about speaker designing then you should get Akabak. If you are not mad before you use this program you will be afterwards, its just really good that it makes you go mad in a way that wants to make other people on this planet have a good time and enjoy themselves though being better able to hear music reproduced more accurately. To finalize I would not jump into an advanced program like Leap without some kind of prior training. You could gain your training in that program but it would be slower doing it in a program that assumes you know what you are doing that in a simpler program that is there to help you. I know you want to do the best job you can quickly, but in the end of the day it’s all about having something to listen to. Starting off on an easier program will enable you to have a working cabinet that will sound really good in weeks. To do the same thing in Leap will take months and probably years. And then as you might have missed something you should have already known, your end product might be not as good as if you had designed it in a simpler program that made sure you understood what you needed to know. If you seriously want to change the world and come up with groundbreaking designs that have multiple patents applied to them like many of the systems I design for Big Mouth Speaker Systems then use Akabak. But be sure this is the direction you want your life to go in, as there’s no turning back.
